5v amp indicator line into control input?
I am trying to integrate the control port inputs to be programed as status indicators or my ATC P4 amplifiers to show \"standby\" or \"protect\" etc. The amps have a \"remote\" port which sends a signal during the appropriate 'status' on a dedicated pin. Problem is, it sends a 5v, not a circuit closure. Is it possible to wire the 5v outputs from the amp to the control inputs? Or, can they only be wired to relays and potentiometers?
  • CinchCinch Posts: 40
    The easiest would be, that you take a 5v relay and wire the coil to your amp-port. then you get the closure contact, that you can wire to the soundweb control port.
    Or... you could switch soundweb to 3 wire mode (meaning that the internal pull-up resistors are deactivated) and then wire the 5V of your amp to a 4.7k resistor going to the soundweb control port. make sure, that you have the 0v side connected to the ground port. then I would add a 10k resistor between the control port and ground in order to have a clear ref when the 5v fall off.
    But as you can see, the relay seems more simple...
