Home BSS User Forum BSS Archive Threads Discussion Soundweb Original
Soundweb Designer on Windows 8
Hello,
I am curious if anybody has had any luck running Soundweb Designer on a PC running Windows 8?? I have some familiarity with Soundwebs, however, I am far from a power user. Any assistance would be highly appreciated.
Thank You in advance.
All The Best,
Chuck \"Chopper\" Boyle
chopper35@gmail.com
  • Soundweb Design will run on Windows but the Event Log will not function.
    If you require full functionality with the Event Log, then you need to run Soundweb Designer on a computer running Windows XP or on a Virtual Machine in Wondows 8.
    Soundweb Designer is not supported on Windows 8 but it works fine.
    Please use the Windows 7 Installer version of Soundweb Designer.
  • JManuelJManuel Posts: 1
    Hi all.
    Any luck yet with London Architect on Windows 8?
  • LA runs under Win8.
    I have used it a couple of times and from memory I had to enable some kind of 'windows 7 compatibility' function inside of windows.
    Can't recall where that was, sorry. My daily machine is Win7 so I can't look.
  • LA will run fine in Win8.1 despite not being supported on that OS.
    Personally I've not had to use any compatibility modes.
  • catwomen424catwomen424 Posts: 1
    edited August 2017
    good
  • This is such a great resource that you are providing and you give it away for free. I love seeing blog that understand the value.
