Blu100 Blu 8v2 issues
Using two blu8v2's to control two zones. Using the buttons for source selection on the last page of the encoders. created two source selectors in the blu100. Setup two logic source/radio button setups. linked them to their respective blu8's. all worked fine. rebooted system and now the source selection is swapped on the blu8's. checked the logic setup and button assignments and all is well. why would a system reboot swap just the selector buttons? all other controls stayed on their respective controllers. is there a boot sequence that is preffered? I've rebooted several times and powered up the blu8s after the blu100. Not sure how to wipe the memory of the blu8s and reload them or if that would help.
  • There is no preferred boot sequence.
    Please contact technical support. Simply complete a support form at the Support page of the BSS Audio website. If you are in the USA then you can also call (800) 931-2357
