change file in online mode
hello
i have system with 806, 160, 100, some bib&bob...
if i need to make changes only in the 160 and save a new file to the system...
can i leave all the other blu's in online mode ?
the system is working as main matrix and prosses at big broadcast station, and every time that i need to make changes in one box i need to come at night and switch all the system to ofline.
thanks.
yoni
thanks.
yoni
It depends on how your system is set up.
If the audio is passing through all (or some of) the devices, then you need to be careful, but if not, you can modify one device and when going back online be sure to RECEIVE from all the other devices. This way, the devices you are not modifying will not pause their operation.
But again - it depends on how it's set up.
Do you have a system diagram/overview/whatever?
Also I can't remember if the devices pause if you've selected to 'Save to device network'. I don't have a device next to me, so could somebody check that?
'Save to Device Network' does NOT cause BLU devices to 'pause' (aka 'stop passing audio'), nor does it change any parameter values running in the box.
and when it do the loading it make drop to the sound for 10-30 seconded.
so i not understand how you say that it should not make a drop ?
and one more thing that i need help... i have 8 pc's with different custom control panels that controlling the bss.
so when i want to update the file and load a new file i must to switch all the pc's to offline. if not it not load's the file.
thanks.
\"Save to Device Network\" is different than \"loading\" (AKA \"going online\"). SaveToDeviceNetwork is a PURELY OPTIONAL exercise of saving the *.architect file to the BSS box, useful in situations where you want to give someone the ability to extract a *.architect file from a BSS box (this is done via File-->Open from Device Network). SaveToDeviceNetwork is functionally equivalent to saving your *.architect file onto a thumb drive, and then physically duct-taping that thumb drive to the box. SaveToDeviceNetwork has NO effect whatsoever on the actual audio processing occurring inside the BLU.
More than 1 control PC on your network... that feature isn't supported by BSS. Read Dan's comments on this thread: http://www.bssaudio.com/phpBB2/viewtopic.php?t=787&postdays=0&postorder=asc&start=0
