Leveller Gate Broken???
Greetings,
It has been brought to my attention that the gate function of the leveller block is broken.
Could someone confirm this?
If is there intention to fix it?
The gate is a valuable function to prevent over-gaining. Without it, the leveller is nothing more than a compressor.
The leveller has not changed and behaves as it always has.
What is broken about the Leveller?
It is my understanding and expectation that more gain should only be applied when input audio is above the threshold.
I'm guessing that you are expecting the gain to go back to 0dB, well that's not the way it's supposed to work. If it did, the gain would be constantly changing as the signal hovers around the Threshold. This would be undesirable.
