iOS Control of Soundweb London - System / Audio Architect
Am I correct that setting up a panel must be done in the legacy System Architect? (Every document / sticky I've seen references SA not AA)
At the moment if I do a right click in a panel in AA to import a parameter from London Architect (right click exported) it simply hangs forever.
Thanks!
  • You can set up a Motion Control panel in SA or AA.
    In SA you have to export/import parameters from London Architect.
    In AA, you don't need to export/import because you can create the Soundweb London Configurations natively. You just drag and drop parameters from the London Configuration directly onto the Motion Control panel.
    Just use the option that suits you best. There's no benefit to either with regards to your requirements.
    If you try to export/import in the current version of AA (v1.20.2), it will hang, as you have discovered. The import option will be removed in the next version (v1.30.0)
