Logic \"Device monitor\"
HiQnet London Architect v6.00
All machines are OK,and all the \"Device monitor\" are high.
shut down the software and some machines.
Go on line. (Whether to send or receive synchronization)
\"Device monitor\" about the shit down machines: Lighting are low,but output be high.
I try to power on the machines and shut down again, \"Device monitor\" can be OK again .
Why?
Why?
Also if you still have trouble it could be a timing issue with he subscription and logic. You can check the get current parameter values while going online (under file preferences>going online.get current parameter values).
Second Check and see if logic subscription is has been turned on under the device properties in the main window. If it is, then turn it off. If it is on then the logic is not subscribed to reduce CPU usage which means you will not see the actual changes when online.
