Select Room Combine with BLU-10
sjabek1
I have a Blu-100 that I have set up a Room Combine object and am having a problem using a BLU-10 to select rooms to combine. I was able to get the Group Selector to work on the Blu-10 but I cannot combine rooms with the Blu-10. I also set up a Control panel page and that works fine
1. Create Partitions in your Room Combine object. Then assign the Partitions to the BLU-10.
2. Create Parameter Presets of different room combinations then assign these Parameter Presets to the BLU-10.
(My preferred way to make Presets is to use the \"Group\" parameters. In the Design Tree you will see that the Room Combine has a \"Group\" parameter for each room. Add these Group parameters to your Parameter Preset Group then, create the Presets.)
