Operate mode - the problem
Hi!
This is my first post on this forum.
Ask you for help. I have not found answers on this forum before.
I have a problem with LA in the \"OPERATE\"
I have created a project in the main window, in the \"DESIGN\" I have a bookmark:
Main: 100% / (BLU-100) Defaul Config: 100% / Matrix Router 100% itc.
Everything is standard as in any project.
The problem appears when I turn the OPERATE mode to change the parameters from objects. Appears blank screen, without prior bookmarks.
I do not have tabs so I can not change the parameters of objects.
I would add that, as creatures of the Customs Panel is in the OPERATE mode appears only Castom Panel, and then have a possibility edition only castom panel.
Whether it is an option that can enable or disable the program?
Please help if anyone knows.
I greet all
Marcin
I greet all
Marcin
The options you are looking for are in: Tools/Application Preferences/Operate
Useful keyboard shortcuts:
SHIFT + F5 Go to Design Mode
CTRL + TAB Switch between Tabs
You are welcome to contact tech support on the BSS Audio website. In addition your local distributor will provide tech support. Find your local distributor on the BUY page of the BSS Audio website. (there is no charge for tech support)
