input noise issues BSS BLU100
I have just completed an install using the BSS BLU 100. everything was fine but sure enough two hours prior to the venue opening a loud intermittent crackling is coming through the system. Fault testing and removing all inputs from the processor did not solve the problem. With all inputs disconnected, on the software screen i am still registering an intermittent input noise. It must be being generated internally? Has anyone seen this before? Help.....
You can find your local distributor from the worldwide distributors list on the BSS website here: http://bssaudio.com/en-US/where_to_buy
Alternatively you can use the Technical Support form on the BSS website here:http://bssaudio.com/en-US/support
Yes, experienced this first hand. A firmware update corrected it. Not sure why, but it did.
