Home BSS User Forum BSS Archive Threads Discussion Omnidrive/Minidrive
bss 336 old firmware
my bss 336 update to 336t v210 firmware ,but it was not use now.
i want old 336 firmware now,thank.
  • Please contact Technical Support on the BSS website.
    Go to bssaudio.com and use the form on the SUPPORT page.
  • f.s.f.s. Posts: 4
    but i can not find the old firmware in suppot,
    could you give me one,please.
  • HARMAN_Jerome_KingHARMAN_Jerome_King Posts: 328
    edited August 2014
    This user was actually using an OEM version of the FDS-336. Installing the firmware for the FDS-336 will not work because there are differences.
    For example, the OEM devices have a different front panel button layout. If the FDS-336 firmware is installed then none of the buttons will work.
  • f.s.f.s. Posts: 4
    i am have 626v107 firmware ,but now i ant not respond the bss miniload,why? how i can into reload mode ?i have use mute 4 5 6
    it is no use. thanks
  • 626v107 was not the correct firmware. Once the correct file was loaded it worked fine.
  • This user was actually using an OEM version of the FDS-336. Installing the firmware for the FDS-336 will not work because there are differences.
    :D:D
