Need help building a stereo Toggle.
Hey there.
I have a BSS 160 with both a Digital and Analog input cards.
The venue that I work at is using different mixers on different nights, sometimes we use a mixer with analog outputs and sometimes with S/PDIF outputs.
I'd like to build a toggle in the BLU10 that allows me to switch between the analog stereo pair and the digital stereo pair.
I'm using a source matrix with 4 inputs and 2 outputs. how can I link the sources to do a follow pattern (IE when I switch output 1 to source 1 then output 2 switches to source 2 and when I switch output 1 to source 3 output 2 switches to source 4).
Linking is explained here: http://bssaudio.com/soundwebtraining/
In properties for the source selectors, set:
Allow None = No
Use Signal Names = Yes
Dan
I ended up doing something else. I assigned the source matrix to a preset and programmed two presets, one for the Analog in and one for the Digital. I then built a logic controller for the presets so that I can toggle them through my BLU-10.
Boris.
Dan are you \"back\"?
Just bored. I wrote that while sitting on a really long conference call listening to a guy from Brand-L video codec company explain the minute details of their gui to a customer. Figured it wouldn't be polite to hang up in the middle of his presentation.
Dan
