Subrange Values for Gain-N input
Hello!
With a mono gain module, I can define the subrange values in the Default Config page, and these then translate correctly on the Blu-10.
With Gain-N input, I can only define the scale subrange values in the module page, and these do not translate correctly on the Blu-10. For example, I do not want the master fader to go above 0db, while this behaviour is correct within London Architect, the BLU-10 will still push to +10db.
Short of using linked Mono Gains, is there another solution ?
Thank you all.
Sidhu
Thank you all.
Sidhu
Now create an exact Link between the Mono Gain fader and the N-Input Gain fader.
Assign the Mono Gain to the BLU-10.
That would work.
Regards,
Sidhu
