Home BSS User Forum BSS Archive Threads Discussion BSS Archive General Discussion
labeling for the speaker in main
Greetings!
I want to label the speaker in main tab according to my like. I tried search in the ready label but was the speaker label 8124 was not there. I have seen some program which having speaker label 8124. Please advise.
Thank you.
  • It is possible to make your own objects to show in the main schematic window. it will require a knowledge of XML programming to achieve this.
    Or, more simply, you could add a speaker from the existing object listing, and change it's name from 'Uxxx' to whatever speaker you desire. Then in properties for the object, switch 'object type' to off, whilst leaving the name, which you have just set, in 'object name' in the properties window on.
