Is 2 x BLU 8 can synchronize themselves automatically ?
In first of all, sorry for my bad english.
I try to explain what I would obtain:
I use 2 rooms with several local audio sources and a BLU8 in each room which controls the sources and volume of that room.
Each BLU 8 can also control sources and volume of the other room.
I need to have the return of sources and volume values for each room on each BLU 8, for know the source used and the volume level into each different room.
I would use the page mode on BLU8. Example : room # 1 - page 1, room # 2 - page 2.
My question is :
Is these values will update automatically in a BLU8 when I'll change page or when I'll modify source or volume parameters on the related page of the other BLU8 ?
If not, how can I obtain that kind of auto synchronization?
Thank you for your help !
My question is :
Yes, the two different BLU-8 controllers should track each other.
