\Jerome King\ wrote: Are you wanting to connect wordclock to a Digital Input Card or a BLU-800/320/806/326 ?
\"Jerome King\" wrote: Yes, you can connect wordclock to the Digital Output card. Wire in the following way: Clock Source / Soundweb ground ground ground negative positive positive This is like a unbalanced to balanced cable. THX
No. BLU-16/160/120……only(without BNC Sync).
Digital Output Card, the Connector2 pin 1&2 is AES/EBU Clock Input.
May I connect the coaxial wordclock ?
ground
ground
ground
negative
positive
positive
