We have a BSS FCS-960 graphic EQ that stays in \"bypass\" mode even when the \"EQ IN\" switch is pushed. That makes it worthless as a graphic EQ. Anyone have any suggestions about causes/solutions?
I realize this is over seven years ago but I just had a NOS unit arrive from eBay with the same behavior. I suspect the issue is the bypass relay oxidation (Omron G5V-2 24v) but I thought I'd check to see if you resolved this problem you were having and what the solution was. Hopefully replying on this thread might send you an email to notify you of the reply!
