Ethernet and Serial Trigger/Table
This guide looks at how to use the Ethernet Trigger and Serial Trigger/Table logic objects. These can be used to send control messages to third party devices via RS232 or Ethernet.
>>> Click here to download the full application guide.<<<
Is there an updated link for this resource? This appears to take you to a few reference designs not the application guide.
I think this link may help you out: https://audioarchitect.harmanpro.com/aa_help/Soundweb_London/Logic_Objects/End/Ethernet_Trigger_Table.htm
I do however have another question about the table: Is there a way to import and export the Ethernet Table to a csv or xml or the likes? I am not looking forward to change a complete 2^8 table by hand...
I have searched quite extensively online and have tried to open the *.audioarchitect file with code editors but to no avail.
Here is a link for the guide on Ethernet and Serial Trigger
https://help.harmanpro.com/using-the-ethernet-trigger-and-serial-trigger-logic-objects
All our guides and more are now on this site.
There is no facility to import or export the table.
Hi Jerome,
Would an import or export be a possible feature in the future? It would add a lot of value for system integration in existing show control and building management system applications. That is where I am using the tables for. It would make it much easier to make a complete table in excel and import it into the table. When I mean import it need not be an actual import button; just a copy a column from excel (Ctrl+C) -> paste (Ctrl+V) values in the table (and vice versa; select all values, Ctrl+C and Ctrl+V into excel).
Cheers!
