The Room Combine processing object becomes available to add into the Configuration once the rooms and groups have been defined.
1. Add Rooms into the Venue in Define Venue Mode.
2. Select the Rooms to combine
3. Go to the Define Venue tab above the ribbon and click Create.
The Room Combine object will now be available to add into the Configuration.
All this information and more is in the Audio Architect Help. Simply search for \"room combine\".
Thanks again!
