Home BSS User Forum BSS Archive Threads Discussion Audio Architect with Soundweb London
Blu100 Bootup parameters
Hi folks! Ima bit flummoxed and cannot find a solution. I have a Blu100 with some simple zone based level and source control. On power up, typically I would expect the programmed values (for source and gain) or the last state values to be recalled. However, on this unit on power up it revert to a fixed source and gain level of -0.11
Any advise appreciated!
I would also like to recall different gain levels during different times of the day, and from my understanding of Scheduler, it seems I can only recall Venue presets, which would also include any state of other attached amplifiers etc. What is the best way to achieve this atumation?
Much gratitude for all your time.
Best
Sid
Answers
  • sidhusidhu Posts: 18
    Hi!
    Said parameters were being recalled to a fixed value as I had some control ports configured without a controller actually attached.
    With regards to scheduling preset recalls (only gains), I would still appreciate some guidance.
    Best!
  • DWSavDWSav Posts: 31
    Really easy
    Audio -
    Drop the values of the objects into a preset(s),
    Logic -
    logic source -AND - Preset table/trigger
    Calendar. -
    Logic source has to be on all the time, set on/off times in the calendar when calendar hits the times set by sound web it will come on/go off accordingly
    You can set up as many calendars/presets as you need
    Don’t forget to set your time zone etc in audio architect
    I do this loads for venues with preset sources/volumes and control strings
    Works really well… not much you can’t do.
    Hope that helps
