Home BSS User Forum BSS Archive Threads Discussion Audio Architect with Soundweb London
BLU 100 controlled by Python
I am trying to gain control of a Blu 100 with python I seem to have gotten it to no longer throw out errors however I am struggling to get the string correct, I have tested with RS-232 and that seems to be of a fan of HEX without any Prefix or separator, here is the code I've used so far
import socket
TCP_IP = '192.250.1.95'
TCP_PORT = 1023
BUFFER_SIZE = 1024
MESSAGE = "02,88,6A,39,1B,82,00,00,1B,82,00,01,00,00,00,00,DA,03"
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((TCP_IP, TCP_PORT))
str (MESSAGE)
data = s.recv(BUFFER_SIZE)
s.close()
Please let me know if I've over looked a setting or if part of the code is wrong
  • I have found a Python script that works now here is the code if anyone else is struggling
    import socket
    import sys
    import struct
    import time
    import binascii
    host = '10.250.1.95'
    port = 1023
    s = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
    #Use HEX without any prefix or Separator
    inputHex = binascii.unhexlify("02886A391B8200001B82000100000001DB03")
    try:
    #remote_ip = socket.gethostbyname(host)
    s.connect((host, port))
    except socket.gaierror:
    print('Hostname could not be resolved Exiting')
    sys.exit()
    print('Socket connected to ' + host + ' on ip ')
    try:
    while True:
    s.send(inputHex)
    print('Message sent Successfully')
    time.sleep(1)
    print('sending')
    except socket.error:
    print('send fail')
    sys.exit()
