Home BSS User Forum BSS Software & Programming
Blu-100 not found on network?
I have a Blu-100 that I am trying to program with audio architect. HiQnet NetSetter has not found the device on the network.
Does the problem have something to do with the IP address?
  • DWSavDWSav Posts: 31
    In net setter top left you can select which NIC to search by.
    You nominally have the wired ethernet NIC and wireless NIC if using a laptop.
    If you still can’t discover use something ike wire shark see what it’s ip range is and
    Adjust your NIC to match.
