Home BSS User Forum BSS Software & Programming
Audio Architect - LED indicating active preset
On a custom control panel I want an LED to turn on (illuminate) when a parameter preset is recalled. I want that same LED to turn off when any parameter in that recalled parameter preset is altered from the saved values. Essentially, an indicator showing which preset is recalled, while also indicating if any parameter has been edited by the LED turning off.
  • DWSavDWSav Posts: 31
    What are you using for control - iPad? Contrio?
  • Just using a Windows machine with custom control panels.
    LED for preset recall - easy.
    The LED extinguish if the preset has been edited..depending on what your editing, possibly a comparator so if a value is changed the logic end goes on/off.
    If it’s a heap of changes prob not.
    Some more info about what the preset is could help?
