Crossover configuration advice for a Venu360
The house system here operates with 2-way stereo mains (mid-high), and 2x single 18" subs running in Mono, being fed by a Stereo LR MAIN and subs on aux from the board.
We're adding a dual 15" to supplement the low end, and I'd like to setup a crossover between the HF sub (dual 15") and LF subs (single 18"s) so they can focus on their respective jobs.
What's the smartest way to treat this in the venu360 in order to get outputs for HighFreqL, HighFreqR, MidL, MidR, HFSubMono, LFSubMono?
Thanks much to all,
jeff
Answers
I would set it up as a Stereo 3 Way system. Go Recall on the preset section of the panel/app and recall preset 6, this will setup your IO for a 2X6 crossover. If you want to Aux your Subs, then recall preset 10.
