Home dbx User Forum dbx Live & Portable Products
260 or PA2 for PRX mains
We use one PRX 735 per side and one PRX 718 per side as mains. 4 pc rock cover band. Want to keep things simple, but also want to have the ability to pink rooms, have had both a PA and 260 in the past, but when I had passive srx's and crowns. Do both the PA2 and 260 have presets that would accommodate this set up, and if so, does it make sense to pick one or the other? Obviously, I can't affect the parameters between the mid speaker and horns in the 735 as its a closed system.
  • EEldeEElde Posts: 1,376
    The PA2 is like a stereo 3 Way Crossover really. The biggest different between it and the 260 is that the PA2 has paired stereo outputs (and the Low can be summed for mono sub) whereas the 260 has 6 outputs that could run at 1X1 mono crossover.
    The PA2 in stereo full range would be pretty easy to use and you can do the AutoEQ feature for the EQ curve utilizing the RTA-Mic
