First Post on the new BBoard section. I do have a question.
My gain stage is setup so that my console and amps clip at the same point. I now turned on the limiter on the DRPA so that my amps can't reach clip. Is this a bad idea? My amps already have clip limiters built in if that would be better. :roll:
double limiters is not a good idea. If you engage the limiters on the amps it will also limit the available power... as in the QSC RMX 2450, engaging the limiter takes the available 2400 watts bridged mono down to about 1800 watts...
:shock:
gadget
Regards,
Thanh Nguyen
Service Development Engineer
QSC Audio Products, Inc.
As I thought I indicated,
I (using the DR260) set the limiter up as a OOPS(brick wall limiter) I accidentally walked away and let you come back here and fuck with my system while I was out checking the room... :evil:
