Crown Power Base 2
limon513limon513 Posts: 6
edited March 2006 in PA Configuration Wizard
Is there any configuration for Crown Power Base 2 amp to be used with a DRPA? Ifso, how should I set the gain knobs and sensitivity switch?
  • GadgetGadget Posts: 4,915
    I would have gone to the Crown International website (which I did) and searched through the \"discontinued\" products (which I did) and gotten the info from the manual (which I didn't, because the manual wouldn't load).
    I tell you what, do a gain structure, with the equipment you have, and let the levels fall where they may...If you REALLY MUST HAVE a figure, try the website yourself, and then try and reconsile that with the gain structure... to me, the gain structure is FAR more important than a \"suggested\" setting...
    gadget
