EV SXA250 and DRIVERACK PA setup
Hi Gadget,
I'm a proud owner of a Driverack PA system. I have 4 EV SXA250 speakers that i want to connect to the PA system, what would be the best configuration for this setup. this setup is for my mobile dj rig.
How do i set compressor and limiter on the PA for my speakers?
here is the specs for the speakers:
Features
Compact 15-inch two-way powered system
Usable as a front-of-house system or as a floor monitor
Separate mic and line inputs with mix capability
350 watt dynamic LF power amplifier
80 watt dynamic HF power amplifier
LF and HF shelving equalization
Line output for cascading signal to additional speakers
80 x 55 degree constant directivity horn
126 dB maximum output capability
Enclosure is built of 18 mm plywood and finished in Futura, a sprayed-on polyurethane finish that is extremely durable.
Comes with metal stand mount and can be safely suspended using optional SK-1 hardware kit
Only 49 lbs
Technical Description
Frequency response (-10 dB): 55 Hz -- 20 kHz
Maximum SPL: 126 dB
Horizontal coverage: 80 degrees
Vertical coverage: 55 degrees
LF amplifier power: 350W 10ms burst, 150W continuous
HF amplifier power: 80W 10ms burst, 50W continuous
Mic input sensitivity: -35 dBu to 0 dBu for full output
Line input sensitivity: -12 dBu to 0 dBu for full output
LF transducer: 15 in.
HF transducer: 1.25 in. exit compression driver
Connectors:
-- Balanced inputs; mic, line: XLR, XLR % 1/4 in. phone combination
-- Balanced output: XLR
Equalization: shelving; LF +/- 6 dB @ 140 Hz, HF +/- 4 dB @ 5 kHz
Power requirement: 110-130 VAC, 50-60 Hz, 600 Watts
Features
Only 49 lbs
Maximum SPL: 126 dB
Connectors:
In this instance ...now get this..absolutley NO compression!, NO Sub harmonic processor, use a bandpass, not a xover.
Do an Auto EQ, using the new method I posted..Here:
http://www.driverack.com/drug/view_thre ... d_id=41419
If I have made an error, its because you didn't provide all the info...
Features
Frequency range (-10 dB): 42 Hz -- 150 Hz
Amplifier design: high-efficiency class H
Output power: 760W (RMS)
THD, rated: <0.05%
Sensitivity (SPL 1W/1m): 100 dB
Maximum calculated SPL: 128 dB
Components: EVS-15FR
Connectors: 2 XLR/jack combo input, 2 XLR slave through, 2 XLR mid-hi output
Level control: +40 dB to -10 dB
Internal crossover: PowerMax 12, 100 Hz
Protection: dynamic limiter, DC, HF high temperature, peak current limiter
Power requirements: 100V, 120V, 230V, 240V
Cabinet: 16mm plywood vented enclosure, 4 whells, pole mount (M20), 2 handles
Well thats better, You still won't want to use a compressor, the speakers allready have limiters so I'd say forget the redundant limiters...just let the speakers do their thing since the limiters are not defeatable anyway.
The xover point will probably end up between 100, and 120 hz. I recomend a L/R24 xover, starting @ 100 hz. The sub allready has an HPF, so tis is going to be pretty easy.
Try the new Auto Eq method as described here...
if you have the RTA mic.
As for delay.. I forgot about the crossover delay... Try 5-7.5 ms on the tops, there should be a spot in there that sound tighter, I really don't like the sub synth...buts thats your call.
let me know how it comes out
gadget
Thanks for the tips. I tried all your instructions and i must say that my systems sounds awesome, and I haven't had any problems with feedbacks since i started using the PA system.
I want to know how I can setup the PA system to use just two of my monitors [EV SXA250] as full range speakers [using either the low our high output connector] without any subs. because sometimes I get gigs to do house parties, and I have noticed that the output from my sub can be alittle too much for such a setting.
