Yamaha MSR100's
MysticalrabbitMysticalrabbit Posts: 2
edited April 2006 in PA Configuration Wizard
:? I run two different systems for DJ depending on what is needed. The big system S115's, JBL 18 Sub and QSC amps was easy to set up using the wizard. My smaller system uses two Yamaha MSR100 speakers with built in amps. What is the best/simplest way to set up these speakers?
  • GadgetGadget Posts: 4,915
    Simplest way would be to choose the C300 from the preset menu. This gets you a band pass filter. There are no other settings entered so that would give you the basics. Then set an HPF and do all the other things we suggest, Try the new indoor auto EQ method here:
    http://www.driverack.com/drug/view_thre ... d_id=41419
    Remember the gain structure..
