DriveRack-PA possibilities?
Hi DBX guys,
Wanted to recheck some previous advice received...
Using all PLX Amplifiers---Currently planning on running 2x5-way x/over setup: Biamp Stereo: L/R High/Mids, L/R Mid Lows (Community XLTE-46) plus Mono Subs (XLTE-55)
Is it possible to \"bypass\" the x/over templates and hook-up an additional set (mono will work) of coaxial \"room delay\" position speakers, utilizing all outputs??
[I understand that a 260 would probably do the job nicely, but that's not what i have.]
Could you explain if/how exactly this can be done using all (6) outputs?
Also would like to know if a room alignment device could be installed inbetween the driverack-PA and the amp for the coaxials?
ThankYou for your time.
gadget
Couldn't get on line for a while................
Sorry to be confusing.
Let me back-up a bit:
CAN i hookup the biamped 46's, the coaxials (mono will work if necessary on those) & a Pair of subs on (6) Six outputs?
(Talk about alignment later)
thanks again
