One question before I buy a DRPA
WynnWynn Posts: 3
edited May 2006 in PA General Discussion
Hello. After not having to worry about the PA for some time, I am soon going to be the PA guy in my band :(
I need to replace some things and I'm thinking the PA is the way to go rather than replacing a bunch of individual components. I've read the literature, and there's only one question I have.
I'm running in mono, which is fine for my purposes, but I need to know if I can EQ the FOH and monitors separately from one another. Maybe a no-brainer to some of you, but I didn't get that out of any of the manuals. Thanks.
  • GadgetGadget Posts: 4,915
    You'd be much happier with the DR260, But it would work marginally. you would have a dual mono GEQ and 3 peq's to use. In the Auto EQ you would have to do each separatly, but thats what you want anyway.
    gadget
  • WynnWynn Posts: 3
    Gadget, I've seen your posts other places saying the same thing. Any reasons in particular?
    the 260 has completely separate or combinable inputs, and is completely separate all the way through the DRPA has everything tied together except the GEQ and PEQ sections.
    In the 260 any input can be routed to any or all outputs, and anything in between. The DRPA is just not set up for two separate systems..
