dbx pa xlr inputs
I'm running an rca out (unbalanced signal) from my preamp to xlr in on the PA. Question does the PA send a true balanced out signal in this configuration? I read somewhere that if you are running un-balanced inputs you get un-balanced outputs unless you short out the + and - pins on the input side. Is this true?
I will elaborate. The unballanced signal in to the driverack is just that, an unballanced input into a ballanced input section, with enough gain to make up for the difference. However, the output XLR's are a differentially ballanced output, and as such are best kept that way all the way to the amps. So, the inputs AND outputs are ballanced. The fact you are sending the driverack an unballanced signal, it is processed and output in a ballanced configuration. The DRPA has a switch in the back that allows for operation in a 'pro' level configuration..+4, and 'consumer' level, -10. This allows for plug and play operation with consumer level gear, which is mostly at the -10 level, and typically doesn't run great distances.
the signal comes into the input. the box takes the average of the balanced signal and converts that average into the digital for processing internally.
then, it is just after the A/D that the signal gets split again into the +/- signals for balanced transmission over the cables.
I believe the configuration is to short the negative to ground, so that positive is the signal, and the ground/negative becomes the new ground.
