Set up help
I have 2 L36 Subs Cerwin vega2 D32D double 10\" cerwin vega 2 V152 on the 2 corners. How should I set them up for maximun performance. I have a crest audoi 900 for the subs a qsc rmx850 for the tops and a crown xls402 for the other corners and a DBX rrive rack. I just need help getting it right!!!
Dan
Dan
Take a look at the PDF file at the below link. It may help you better understand the setup procedure for the Driverack PA.
http://www.driverack.com/drug/view_thre ... d_id=41682
