Home dbx User Forum dbx Archive Threads DriverRack PA & DriveRack PA+ PA Front Panel
Front Panel Blackout
Papa CPapa C Posts: 2
edited September 2006 in PA Front Panel
I have experienced the front panel blacken out when the DRPA is turned on.
After reading a few of your forum discussions, I decided to look inside and make sure the ribbon connectors were not loose.
It must have worked because Now after over a hundred cycle on/offs the screen is working fine.
Just thought I would add that little tidbit.
  • GadgetGadget Posts: 4,915
    Cool Thanks!
  • Wow... what a lifesaver! I was getting ready to take my DRPA into the shop with a blacked out screen when I saw this post. I removed the metal enclosure cabinet and snugged up the connector for the ribbon located just behind the screen. I put it back together, plugged it in, and IT WORKED!!!
    This little problem happened at the worst possible time as I have a big show to do and didn't have time to put it in the shop. I have become very reliant on this piece of equipment and wouldn't want to have to go back to \"the old way\" of running the FOH and monitors. Thanks to the poster for taking the time to share the info.
