2x stereo outputs?
Hello
I'm wondering if it's possible to have 2x Stereo FULL RANGE outputs?
What I want to do is to have the first stereo outs to my Main speakers and the second sets of stereo outputs to another pair of speakers will delays. So that I could use them as Delay Tower.
How much delay are you thinking about using?
You can setup the PA for 4-6 full range outs by selecting a biamped or triamped configuration in the Wizard and then changing the x-over points. However, as for the delay, the PA only offers enough delay for driver alignment. There is only 10 ms (about 11 ft) to work with. So if you need more than 11 ft, unfortunately, you would need a 260 to do this properly.
