DRPA with Crown XTi-4000 Vs. QSC PLX 3402 for JBL SR-X Cabs
I'm rethinking my plan of attack with my new rack.
Here is my current system:
(6) QSC PLX 3402's
(4) JBL SR4733X's
(2) JBL SR4719X's
(1) DBX DriveRack PA
I looked at JBL's web site and they recommend using 4 Crown XTi-4000's with my system. 2 bridged to the subs and 2 stereo to the tops. This would lighten my amp rack, require less wiring and give me space for more equipment in the future. What do you guys think?
Thanks for the help!
Phil
(6) QSC PLX 3402's
(4) JBL SR4733X's
(2) JBL SR4719X's
Phil
Just my $.02
Thanks for the reply. I could run 4 PLX 3402's, 2 bridged for the 2 subs, 2 stereo for the 4 top's low biamp, and 2 PLX 2402's to the 4 top's hi biamp. Am I closer?
Phil
Otherwise, I recommend those PLX's. They sound very musical, are very robust, and not that much heavier...They are universally accepted, and I think you will find that you will be much happier with them...
Even though they are not in the presets its easy to set them up..don't let those Harmon assholes fool you, a preset is no reason to choose one amp over another... Sound quality is paramount, and I know you will like the QSC's!
Thats my $.02
Think of it this way... too much power is never enough... If you have all the amps the same and one goes ... you still have plenty of power... and universal exchange-ability...
you can always turn it down.. but when its all the way up and its not enough.. then what.. blown drivers.. thats what!
Its like when your hot and your naked.. how much more can you take off? If its cooler you can always add more cloths.. Thats only an analogy... you can always turn a too powerfull amp down, but once you run out of power the game is over... you will destroy something!
4 - 3402's
2 - 2402's
So it looks like I could power my system like this:
2 - 3402's bridged powering 1 - SR4719X each
2 - 3402's stereo powering 4 - SR4733X LF in bi-amp mode
1 or 2 - 2402's steroe powering 4 - SR4733X HF in bi-amp mode
I'm trying to do the math on the power needed vs. power rating of the PLX 2402 for 4 HF drivers of the SR4733X's. Also, do I run the subs in discrete mode?
Thanks for all the help!
Phil
I agree with you...
I would still only use 1 amp for the comp drivers even if its a 3402
Why carry 2 if 1 will do the job...I'm old.......that 20 some extra pounds could be the end of me....
FWIW.... I run a system very similar to the 1 in question, but I run 2402's bridged LF (4719's) 3402's stereo MF and a 1202 stereo HF....seems to work well for me.
I do need to thank you Gadget....When I was interested in buying a Driverack your posts' on here made it an easy decision. DBX should toss you a 4800.....You have helped many people with problems they are having with the Driverack....Myself included.
Kenny
That is what I'll be working with this weekend......subs will be under the stage......tops will be on stage.....stage is 5 ft above ground level
kenny
I try, and you are correct. I just believe in more power than less... It really makes a difference in the tightness of the bass. I agree, even the 2402 should be able to run the horns. I on the other hand run stereo... evenn if only running the effects in stereo. Its also on a lot of riders these days...I'm old too probably older than you... but an xtra 20 lbs versus low power..
I would love for them to give me one, I figure what with 4 years + and thousands of posts, plus the untold thousands of units I have sold for them its the least they could do... but they won't...
Pure energy.. the SR4733X are 4 ohms, best bet run two of the 3402's in stereo for the subs
run the other two 3402's on the mids.. bridged, and the 2402's/ or as Kenny suggested one would most likely do.. on the horns...
Not optimum power.. but.. now if you had those 6 3402's like you said in the first post...
Let us know how it works K?
gadget
Stereo on the subs? Do you mean amps bridged and 1 to each sub?
Bridged on the mids? That would be be 2 ohms!
Stereo on the 2 2402's to the Horns?
Sorry for the mixup... I am quite blind at times...
2 - SR4719X's each powered by 1 PLX 3402 in bridge mode
4 - SR4733X in biamp mode with LF powered by 2 PLX 3402's in stereo mode, HF of the SR4733's powered by one PLX 3402 in stereo mode
My goal is to not have the system under powered. That is why I sold all my Crown MacroTech’s. I would have needed 3 more amps and 3 more available circuits to bring the system up to power specs. Too expensive and hard to find enough AC power!
FYI...I have 3 PLX 3402's in my monitor rack...maybe I could swap 2 of them for the 2 PLX 2402's I have and move the 3402's into my FOH rack for more power.
My monitor rack currently has 3 PLX 3402's powering 6 separate monitor mixes. I am using 4 MPro 412's and 2 MPro 415's. Sometimes I do have to put 2 speakers on 1 mix. Would powering the 412's with the 2402’s be O.K.?
Crap...too many options...! Basically I own enough to make all this work, but my brain is going to explode trying to figure out the best way to power everything! Based on what I currently own, what should I do?
My amp and speaker inventory for my B system is as follows...
1 - DRPA
7 - QSC PLX 3402's
2 - QSC PLX 3402's
2 - JBL SR4719X's
4 - JBL SR4733X's
4 - JBL MPro 412's (monitors)
2 - JBL MPro 415's (monitors)
Thanks to all for your valuable help!
Phil
Try what I gave you ... the only other option is a couple more 2402's and 1 per top and 1200 watts per speaker/driver. if you get more subs then we will have to reconfigure.. till then I think you'll be ok
Phil
I used the set-up wizard to input my JBL speaker tunings and hooked-up everything the way you said...system sounds lame! The LF on the top cabs have no vocals...mostly muddy! I have the tuning from JBLs website but have no idea how to manipulate the settings. Can you help? I might need a step by step lesson!
Thanks A Bunch,
Phil
Yo need to get the total system configuration the way it is now.. as I read back there was some switching around of amps? what is the config now? are you running the tops bi-amp? If you want you can call me @ 218-999-7100 and we can discuss it easier than all this typing... The tunings from JBL are just PEQ's and delay settings.. and sometimes polarity shifts.
Thanks for the phone conversation....it really helped!
Phil
