GIRL THAT NEEDS HELP W/HER NEW DBX PA
carolinacarolina Posts: 2
edited August 2006 in PA Configuration Wizard
:roll: HI, EVERYONE, I`M NEW ON THIS AND NEED SOME HELP CONECTING THE DRIVE RACK PA, CAN SOMEBODY EXPLAIN HOW TO SET IT UP STEP BY STEP?
WELL I`M USING:
A NON POWERED MACKIE MIXER 16 CHANELL
TWO SAMSON 15\" LOUDPOWERED SPEAKERS
TWO SAMSON POWERED MONITORS
THE FOLLOWIN ARE THE CONNECTIONS I MADE,
I CONNECTED THE TWO SPEAKERS TO THE HIGHTS
THE MONITORS TO THE MIDS
AND THE MIXER FROM THE MIXER OUTPUT TO THE DBX INPUTS
ALL WITH THE CABLES THAT CAN BE USED W THE MICS.
THEN I PRESSED THE WIZARD SET UP, BUT WHEN I GOT TO THE KIND OF SPEAKERS I HAVE ,IT DIDN`T HAVE THE OPTION FOR SAMSON, ALSO IT TELLS ME TO PUT MY AMPLIFIER AND SUBS, AND I DONT HAVE THAT, DO I NEED TO BUY THAT OR I CAN USE IT W/ WHAT I HAVE.
NEED HELP PLEASE........
  • AJayAJay Posts: 28
    I have some questions for you first:
    are these monitors as in studio monitors or wedge monitors for the stage?
    How do you want the setup to turn out? what do you want each of the speakers used for?
  • GadgetGadget Posts: 4,915
    That, and system primary function.
    I might add that all caps is considered yelling, and is considered bad form...
    The more information you provide, the better we can answer your questions...
