phantom power
blueberryblueberry Posts: 3
edited September 2006 in PA General Discussion
I have a customer who has a Pioneer DJM-400 DJ Mixer. It has unbalanced rca outputs and I want to balance the signal into the drive rack with a
http://www.radialeng.com/di-jpc.htm . Its an active box and works amazing if there is phantom on the line. I know from reading the manual the RTA has phantom but am wondering if the left/right in does as well? I'm guessing NO !
I wont be able to try it till next week and just wondering if anyone can give me a heads up to save me time? I can sub a passive Radial box http://www.radialeng.com/re-proav1.htm
for the job but will have to order it and I have the the active box already.
thanks
Bruce
  • The DRPA has phantom power for use with than RTA mic only, not on the inputs. The DI box you linked to uses phantom power from the mixer to convert -10dB consumer to +4dB balanced XLR mic-level output...in place of internal batteries or an external power supply
    As the active box you have is designed more for computer sound cards and mic-level applications, a passive DI box would probably be a better move.
    C
  • thanks Cory......that tells me what I need to know about the inputs on the DBX unit....
    The first DI box mentioned has Jenson transformers and was designed for more of a pro solution in regards to dynamic range and signal usually being routed to a pro audio console and PA . I highly recommend it ...this is an incredible problem solver for all thsoe crappy preamps PC's and other consumer products come with and then send signal to a half million dollar sound system. A sound system is only as good as it's weakest link !
    The passive will be fine for this application ,I just don't have it on hand.
    Cheers !
    Bruce
