Nearfield Auto Eq Methodology
What is the recommended distance from speaker to microphone and microphone to the floor?
Is the reflective surface - concrete vs wood (as you show) vs earth important? A PZM has the metal body of the mic housing as its boundry, would a sheet of aluminum be a good choice?
Do you still set the output to the desired max (say 105db) for the space where you'll be performing?
Does this method work as well for setting a baseline as an open field? It is certainly easier to find an open 25sq ft area than getting alt least 50' from a reflective surface!
