recommended settings
My Setup
DriveRack PA
dbx RTA-M
Crown CE-2000
Crown XTi-1000
QSC-RMX 5050
(2)BEYMA CP22 BULLET TWEETER=XTi-Crown-1000
(2)JBL-JRX125=CE-2000 Crown
(2)ZEAW-SB250zr(Sub)=QSC-RMX 5050
JBL JRX125 Specifications
Frequency Range (-10dB): 35Hz - 16kHz
Frequency Response: (3dB): 45Hz - 12kHz
Sensitivity (1W/1m): 100dB SPL
Nominal Impedance: 4 Ohms
Power Capacity (continuous, 100-hour power test): 500 Watts
Peak Power Capacity: 2000 Watts
Recommended Amplifier Power: 500 Watts to 1000 Watts into 4 Ohms
Maximum SPL: 133dB
Nominal Dispersion: 90° x 50°
Crossover Frequency: 2kHz
Dimensions: 43.25 x 18.25 x 17\" (1099 x 464 x 432mm)
Weight: 94 lbs. (42.6 kg)
High Frequency Driver: JBL 2412 1\" exit compression driver mounted on Progressive Transitionâ„¢ Waveguide
Low Frequency Driver: JBL M115-8 x 2
Input Connector: Neutrik® Speakon® NL-4 (x1); 1/4\" TS phone jack (x1);
ZEAW-SB250zp Specifications
ftp://ftp.eaw.com/Loudspeaker_Product_I ... S_revA.pdf
BEYMA CP22/Specifications
Impedance
8 ohms
Minimum Impedance
8.5 ohms @ 9.0 khz
D.C. Resistance 6.1 ohms
AES Power Rating 25 Watts
Program Power 50 Watts
Sensitivity (1W/1m) 107dB 1w @ 1m
Frequency Response
4kHz - 20kHz
Recommended Crossover 5.0 kHz or higher
Dispersion (H x V) 40° Conical
Voice Coil Diameter 1.5\" / 37.6mm
Magnetic Assembly Weight 2.64 lb. / 1.2 kg.
Flux Density 1.55T
BL Factor 5.2 N/A
Mounting Information
Overall Diameter 4\" x 4\" / 102mm x 102mm
Overall Depth 2.79\" / 71mm
Baffle Cutout Dimensions 3.62\" / 92mm
Bolt Circle Diameter 4.21\" / 107mm
Net Weight 3.5 lb. / 1.6 kg.
Shipping Weight 7.67 lb. / 3.67 kg.
Materials
Diaphragm Aluminum
Voice Coil Edgewound Aluminum Ribbon
Voice Coil Former Kapton
Magnet Ferrite
PLease
i Do all The Set up Good
i put all Custume
i need help only on the EX-OVER
DriveRack PA
dbx RTA-M
Crown CE-2000
Crown XTi-1000
QSC-RMX 5050
Maximum SPL: 133dB
Impedance
8 ohms
Minimum Impedance
8.5 ohms @ 9.0 khz
Frequency Response
4kHz - 20kHz
Flux Density 1.55T
BL Factor 5.2 N/A
Materials
Diaphragm Aluminum
Magnet Ferrite
PLease
i put all Custume
