I am lost
Hi, first off, great forum.
Here is my problem. I do karaoke shows in the same bar every weekend and want the best sound possible. It is a relatively small bar and has 2 permanent speakers which are not mine, so I have to deal with them. They are jbl tr125's mounted near the ceiling at 10'. I use a qsc rmx1450 amp, a compressor for vocals only and a mackie mixer. What settings should I use on my new driverack pa ? I have the rta mic also. This is a big step up for me from just a 231 eq. Thank you, Mike
I need help.
I need help.
I have to tell you I am not much of a JBL fan to begin with..I think those are the worst SPEAKERS they have ever built...I'm not sure even the Driverack can make those crappy things sound good.. RANT OFF...
I guess I would suggest you go to the \"FORMER FORUM\" and read all you can. you will find a plethora of information and suggestions I have made that should keep you busy for a while. then when you have some more specific questions come back and ask whatever you want.
Those things have no low end capability what so ever so good luck there, if you have a sub you could bring it would be a good idea...I guess I'd use the RTA mic and set the DRPA for flat and try abd get on axsis at about 5-6 feet away and see what happens...remember the low end will have to be set by ear...
Let me know
I want the quality and the money issue is the second factor for a pair of speakers, thank you
gadget
