Okay, this is what I'm doing. Is it right?
I'm working through the Wizard and I want to know if I'm on the right track.
For this show. Simple setup. Only 2 Mackie 450 acitve mains ( The amps are built into the speakers), No subwoofer.
I'm working throught the SYSTEM SETUP
Input status: Stereo
Graphic EQ setup: Stereo Linked
Main Speaker: Custom Biamp
Subspeaker: None
High amp: Custom
Low amp: custom
Do you think I'm on the right track?
Another question: How come this preset isn't saved in the main menu?
Still another question: What output do I hook the mains up to on the back? High? Med? Certainly not low...
Thank you for the help. I'm in Alaska and, most people here have never heard of such a crazy gizmo.
Subspeaker: None
High amp: Custom
Low amp: custom
Yes, your on the right track, but the preset IS in there its the C300 and its the unpowered version of the SRM450's and yes you would use the HI outs...Those xovers are all listed in the manual and they show which outputs are used.
Just to clarify. You say that there is a preset for using just two Active SRM450s (Mackie). And the preset is called C300?
