recording output
Hi, is it possible to set up my drpa to get an output for recording purposes? i run it with 2 x jbl eon's, 1x crown amp and 1x active custom sub. Is it possible to get a stereo output to my cd recorder? :?:
thank you
thank you
by the way what interconnects do you use for this? xlr to rca or you convert it to digital?
ps. I think i would need a 2x5 configuration
thanx again for the help
The auto eq works with the GEQ which is PRE crossover, so it would affect ALL outputs.
With mono subs yes a 2 x5 would be fine.
you would use the hi and lo outs for the speakers.. set the hi outs to do the top speakers, and select a crossover frequency.. probably 75 -100 hz LR 24 set the subs to the same frequency you chose...some spread there may work to lessen the crossover region interaction, but some experimenting will be necessary. A hi-pass would probably not be necessary unless you want to protect your subs.
As for the mid outs they would be set to a bandpass... that means you would drag the HPF to out low freq and the LPF to out Hi this would allow all frequencies to pass.
I guess that we are talking about the XLR controls since the Driverack doesn't have digital outs...
