Setup
bubbabubba Posts: 17
edited July 2008 in PA General Discussion
Hello
What setup would give me the best possible sound and spl.
the system is a pair of yorkville performance y253 and community subs XLT 55. Is it better to use full range with sub or 2x3 stereo.
Appreciate the help.
  • GadgetGadget Posts: 4,915
    I'd set up a custom 2x3 in the wizard...I'll have to have more info to be more specific..
    gadget
  • bubbabubba Posts: 17
    the y253 are full range cab 400w pgm. and the sub are 750 watts pgm power
    all passive
    freq response 60-19khz yorkville y253
    freg response 40-150hz
    recommended 100-150hz xlt55 sub
    Is this what your asking for.
    No what amps ..
    Ok
    I have 3 amps crown ce 1000, qsc rmx 2450 and a crown macrotech 3600vz.
    I'm thinking of running the yorkville on the ce 1000 and the xlts on the rmx
    well.. I couldn't get the info I wanted but I presume the Yorkies are not biampable.. I would make them so and triamp the setup with a 2X6... but thats me I recomend that you skip the ce 1ooo and RMX the yorkies and 3600 the T55... the cabs are 4 ohms so you can't really parallel them and the extra power will add definition and punch to the bass and snap to the tops. I would suggest trying a BW 18 @ 40 hz if you want to keep your subs from haveing stress problems, and a LR 24 @ 90 hz for the LPF Likewise with the Yorkies, a L/R 24 @ 90hz HPF would set you up fairly well.. there is no LPF on the hi outs...so that would be said to go to out...
    Your going to have a problem with the gain structure with the Mac but do so for the other items in the system and then see where you end up... If when you plug the speakers back in the tops are loudest, turn them down if the subs are loudest turn them down... but set a nice balance between the two and when the system is full tilt boogie be conscious of the ODEP lights on the 3600.. if it starts to dim your running out of power in the power supply and you better back of a bit... if the lights go out your speakers will be right behind them and the smoke will be let out.. and that is a VERY bad thing to see...
    Thanks gadget. Unfortunately only one of the Yorkies is biamp. I haven't received the new crossover from Yorkville as yet for the other cab.
    Gadget, Dra, kpippen
    Thanks for your help. However I have change my yorkville speakers to the yorkville YX 215. My setup will now be 2x6. Should I swap the MA 3600VZ for RMX 2450. Would it be easy if I don't use the auto EQ and insert an eq before the DRPA and leave the GEQ flatten and make my adjustment from EQ. Inaddition, the I'm thinking of using a 2khz@LR24 and HPF 1HKZ@LR24. would this be effiecient
    System Type 2-Way
    Active or Passive 2-Way
    Program Power (Watts) 600
    Biampable Yes
    Nominal Impedance (Ohms) 4
    Sensitivity (dB @1Watt/1m) 99
    Max SPL (dB) 126.7
    Frequency Response (Hz +/- 3db) 55 - 20k
    Crossover Frequency (Hz) 1800
    Loudspeaker Type: Ported subwoofer
    Operating Range: 40 Hz - 150 Hz
    40 Hz - 150 Hz (+/-5dB)
    Max Input Ratings: 300W continuous, 750W program
    35 volts RMS, 77 volts momentary peak
    Recommended Power Amplifier:
    630W to 900W @ 4 Ohms
    Sensitivity 1W/1m: 98 dB SPL (40 Hz - 160 Hz 1/3 octave bands)
    Maximum Output: 123 dB SPL / 130 dB SPL (peak)
    Nominal Impedance: 4 Ohms
    Min Impedance: 4.4 Ohms @ 50 Hz
    Nominal -6 dB Beamwidth:
    360° H x 360° V
    Axial Q / DI: 1 / 0, 40 Hz - 150 Hz
    High Pass Output: 150 Hz (1/4 inch jack)
    Recommended Signal Processing:
    100 Hz - 150 Hz electronic crossover
    35 Hz high pass filter
    Drivers: (2) 15\", Ferrofluid-cooled
    crown CE1000 for High
    RMX 2450 for Mid
    MA 3600VZ for Low
    thanks
    Gadget can you assist me on doing 2X6 setup I have only been using the system 2x4 with the suggested settings use recommended by you
    well... the Y series are discontinued...the spec sheet I found shows a 2way 2x15 and a 60 h X 30 v pattern, but says that the crossover is 3000, and 8000 hz...???????????????????????
    Without some More info on the horn I will be hard pressed to give you any direction here...
    I need to know what driver the speaker uses... make, and model, or something more definitive than what is published...
    edited July 2008
    I'm no longer using the y series but the YX 215 Here's spec.s
    System Type 2-Way
    Biampable Yes
    Max SPL (dB) 126.7
    Driver Configuration 2x15 inch / 1.4 inch
    HF Driver(s) 1.4 inch Aluminum (1 inch Throat)
    HF Horn Injection Molded ABS
    HF Dispersion (°H x °V) 90 x 30
    HF Protection CTLâ„¢
    LF Driver(s) 2x15 inch Ceramic
    LF Program Power(Watts) 600
    Inputs - 1/4\" Jacks 2
    Inputs - Speakon 4-pin 2
    Corners Metal
    Feet Plastic Glides
    Bar Handles 2 (Side) 1 (Back)
    Enclosure Materials 15mm (5/8inch) Plywood
    Grille Custom Punched Black Perforated Metal
    Covering / Finish Black Ozite
    Dimensions (DWH xbackW, inches) 21.25 x 19.25 x 42 x 12
    Dimensions (DWH xbackW, cm) 54 x 48.9 x 106.7 x 30.5
    Weight (lbs/kg) 78 / 35.4
    * Specifications subject to change without notice
    The YX Series cabinets use injection molded 90 x 30 degree horns with 1-inch throat and 1.4-inch Celestion neodymium compression drivers
    Ok, well the answers are right there...
    Good power for the subs...
    BAD power for the mids...
    plenty of power for the horns...
    Since you run stereo... and seem to have 2 subs? that are 4 ohms.. we still need the preponderance of power on the subs... so...
    SUBS
    HPF 40 hz BW18
    LPF 120hz LR24 (or the closest lower freq available on the DRPA to get our frequency split)
    Yorkville Mids...
    HPF again 120 hz LR24
    LPF 1800 hz
    Yorkville horns
    HPF 1800hz @ LR24 ( a slight split may or may not be necessary here...)
    LPF out...
