feedback
i wonder if anyone out there could explain a couple of things to me and maybe give me some tips on how to eliminate feedback?I have the afs switched on and have 6 live filters.I am still getting feedback through the microphones,I do not have the correct dbx mic to properly go through the eq wizard,is there anyway round?Am also a little confused as to how to set the filters as it can be for speech or music medium high etc and how long to set the filters for?Any help would be gratefully received as don't seem to be able to get it to do its job!
Just a quick up date as I was't too specific about my equipment,I run a chevin amp 1600 w per side,2 logic system x24 top caps with 12\" drivers and 2 \" horns and the very large 2 times 15\"driver per side logic system bass bins.I only use in ear monitors,we have 2 sennheiser cordless mics.Mackie desk.All the music comes from a laptop with seperate sound card.Also wondered when I finally get it set right if I have to set the afs every gig?Obviously not 1 piece of my equipment is in the pre sets so have to use the custom options.
make sure that the speakers are far enough in front of the mics that the mics can't \"see\" the speakers
get the energy from the speakers on the people and off the reflective surfaces
set everything up and get all mics roughed in FOH and monitors
Try and ring out the monitors first and make sure they aren't the problem
once everything is set up select \"AFS\" on, \"music High\", set the lift for 5 sec
Start raising the master fader \"again with ALL mics up to concert setting.. till the first feedback occurs, that should set the first filter.
raise it some more till the next one sets...and so on till you are SCREAMIN loud or the 6 filters are set...
The roamers should take care of the rest.
I mean I have guys running around out front with wireless mics and SCREAMIN at the top of their lungs, right in front of the speakers! and my monitors will rip your head off and you can point the mics RIGHT AT THE MONITORS...and no feedback...I've had performers walk up to a perfectly quite stage and bark into the mics and just about S**T themselves and get this big grin and say this is the first time EVER I have said this... but could you turn those things DOWN!
The technology does work... but my system is tuned to the nuts also....
I see DRA snuck in here...Yo thanks man...
I've just got the Driverack PA - which surprisingly is perfect for what I'm doing (amplified violin) - and I'd just like to know how the fixed frequencies get decided upon.
If you have no feedback and you set all the frequencies to fixed, what frequencies does it set them to?
Is setting the unit to all Live and turning off the reset the same as using all FIXED?
Tom
You have a bit of a quandry here. CAN you make it feed back? If not, don't even use it. By nature, the AFS may \"hear\" long notes as \"feedback\" and notch them out, whether fixed or life. The fixed filters are \"decided on\" by the frequencies that present themselves as feedback, which are typically mic'ed sources. If you select 8 fixed filters the DRPA AFS (if on) will notch out the first 8 \"feedbacks\" that it \"sees\" and permanently notch those during \"sound check\". The rest are for \"on the fly\" problems. , and are typically allowed to reset (roam) throughout the show. If you mic your violin, then I'd say use it, if a pick-up has been installed or it is an electronic violin, then most likely, not.
