advice on crossover etc for setting up JBL system
I am replacing a JBL M552 crossover for a driverack PA on the following system.
2 JBL 4647a Low freq. cabs
4 JBL 2446h Hi Freq compression drivers
This is a center hung flown cluster in an auditorium, currently it is crossed over around 1k I would love to hear your advice it is a mono rig. The specs for the speakers are as follows.
JBL 4647a
http://www.jblpro.com/pub/cinema/4647a.pdf
JBL 2446h
http://www.jblpro.com/pages/pub/components/2446.pdf
Thanks in advance for your help.
Adam Akers
akersa@bethelks.edu
JBL 4647a
JBL 2446h
Adam Akers
akersa@bethelks.edu
You would need to just go into setup wizard. first chose MONO in initial setup, GEQ setup chose stereo linked, for main speakers, choose custom bi-amped, and for sub choose custom stereo (\"Custom\" speakers are at the end). Don't know your amps, so once again, you can choose custom.
Now, go to XOVER, and dial in the settings you want. I'm assuming you want the 4647's on the Low input, and the 2446's on the highs. In the crossover wizard, use the prev pg and next pg buttons to get to the diffrent speakers, and select (press the knob in) to switch parameters of the xover. and the knob to adjust the values in the xover.
after that, you can tweek the system using the EQ's or easier if you have RTA mic you can use the Auto EQ feature in the wizard.
Adam Akers
akersa@bethelks.edu
Adam Akers
akersa@bethelks.edu
Just installed a all EAW sound system in a club and having the ability to run the driveware software and Smaart made the deley factors and everything a DREAM to set up!!!
