How will a DRPA work with monitors?
I figure I could do two separate monitor mixes via the DR PA. I will be using a crown XTi 2000 left for one mix and right for the other mix. I will use FBT Maxx4 passive speakers.
Is this a good way to go??
How can I load the info into the DR PA!?!?
So there you have it.
I have (what I thought) was a simple configuration. I just need a mono full-range main and a mono full-range monitor line. I plan on connecting the outputs (xlr) of a Carvin non-powered rx12000 to the 2 inputs of the DRPA. One line will serve the Mains and the other the Monitors. What is that, a 2X2 configuration?
I currently have a frankenstien configuration of a dbx 266 compressor, 2 mono Sabine feedback eliminators and a digital delay box. I use the delay between the signal from the mixer and the monitor amp; to compensate for sound bouncing off the wall at the end of the bar from the mains. I compress the Main signal and add feedback elimination to both channels.
I guess I was hoping I could use the DRPA to get rid of all that stuff. I want to send Left to the Main Amp and Right the Monitor Amp. Add Feedback Elimination to both channels, Compressor to the Left Channel and Delay to the Right Channel. Can I configure the DRPA to do that?
Done the road, I would like to replace my amps with powered speakers and possibly create a stereo bi-amp situation. Again, where do the Monitors tie in?
Since the cost of the DR260 is roughly twice that of a DRPA, would I be better off getting a 260 or 2 PA's? Or perhaps this line of products isn't for me at all.
<smart aleck>
Silly me; I thought 'Complete Equalization & Loudspeaker Control System' included such things as Monitor Speakers.
</smart aleck>
I'm really not interested in bi-amp or tr-amping. I don't think I use enough power for that (I use a single qvs 800; half for the monitors and half for the mains), so my primary need is ...
1) feedback elimination
2) compression on Mains in either Stereo or Mono
3) slight delay on the monitor feed
So, I can't even do that with a DRPA? Thanks much for your input.
Ken
The 260 is 10 times the unit for 3/4 the price.. around $700 last I checked...
I'd defiantly opr for the 260...
I'm pure noob and value the expertise I find here.
Jim
Jim
Dennis
As for the post... is there a question in there? because monitors are a never ending series of war dances done by completely deaf individuals that are arrogant, self centered, and egocentric...then there's the guitar players
Look, if your sending the monitors to the stage from FOH... you send them from a \"pre fader\" aux send right? so... I admit that a 4800 is a WAY COOL monitor processor.. and my bands have agreed whole heartedly... again...what is the question?
My monitors are bi amped and consist of two twelve inch speakers and one 2 inch horn, They are old clair brothers boxes. I am using PLX 3102 amps.
I run 4 monitor mixes most of the time. My question is, can I use two DRPA to create 4 mixes?
Aux 1 to left aux 2 to right first box These two are the same boxes
aux 3 to left and aux 4 to right second box?
3 is the same as the first two and 4 is the drum monitor Different setup
The kicker is the 4th mix is the drum monitor that I would like to use a different system on. The first three monitors would cross at about 1.2 K between the 12's and the horn. The drum monitor is a EAW Rig with a 2 - 15 sub and a 3 way box on top so they would cross at about 80 to 100 HZ.
Can I do this?
What will I not be able to use? I was told I could seperate the EQ, I knew that but that after that all functions would be linked. Is that true?
What setting would I start with on the front of the unit?
I am really quite familier with it but the nervouse type that would rather ask than assume and blow stuff up/ Thanks in advance
Ya... you can... IF... you select \"dual mono\" you will have the input GEQ and output PEQ's to work with... that is... 3 PEQ's per \"hi\" out, and 2 PEQ's per mid and lo out....If you go to the manual you will find a block diagram that will pretty much tell the tale of what is linked and what is separable...is that a word? I guess so...
So, you can (in dual mono) eq the two separately....use the Auto EQ ...separately...and set up the crossovers separately...the 260 on up offer MUCH more...
Separatable is a word.
I've tried to work out how to get a stereo x-over to work for 2 different set-ups. While I guess it is doable, not too practical. Seems like you'd set up a 3 way. Use the hi & mid for the 1200hz singles, then use the mid and low for the 80hz divide for the drum box. This forces you to cut 80hz and down from your 4 wedges, which can be good. This does force you also to sum the hi & mid back together for the drum mon top. Gain control in the x-over is now history and you HAVE to use the amp's attenuators. I'd add an external analog x-over and run it out the "full range" low. Then you could drop the mid HPF some.
NLP
The 260 will work each channel independent of each other and the DRPA will not, You can unlink some of the things but not all of them. I dont know if this is still true with the new DRPA!!
When you can use the Feedback eliminator on the 260, see what it is doing on the computer, go in and use the PEQ to take the problems out and then free up the FB elim to do more, it is fantastic! On top of that the GEQ is still there to use if you want and you can Set your HP and LP filters just to name a few things!
Get a couple used 260's and dont look back. By the way, the 260 can use the snake for your communications so you dont need a hub or wireless router !! Just a a DB9 and a null modem and your talking to it!
