Set up for Peavey/Crown/QSC
We justed ordered a new Driverack PA. It's on the way and I could use a little help getting started with the setup. I'd appreciate any help at all. We're using the following bi-amped Mono:
Mackie CFX16
Peavey DTH 4210f (Mids/Highs)
Peavey DTH 215b(Subs)
Crown CE1000-Mids and Highs
QSC 3402-Subs
Thanks for any help/advice you can give. Please, No Peavey bashing, it's all we could afford...
Mackie CFX16
QSC 3402-Subs
No can do pal... that amp is NOT capable of driving a 1.5 ohm load...no way! those speakers are minimum 3.2 ohms each and if you parallel them in a mono configuration you will BLOW that amp! Same with the QSC and the 215's. You'll need to run stereo and then your under powered! Uless you have one CE per top and one 3402 per sub. DON\"T DO IT!
So with that in mind, those tops fall off like a rock at 120 hz and are 3 db down @ 115 hz. AND, since subs have a tendency to sound honky the higher they go, I guess I would start @ 120 hz.. that said also:
Set a BW 18 HPF @45 hz and a 120hz LPF @ LR 24 for the subs...
Set a HPF @ 120 hz LR 24 for the tops and sweep the delay to somewhere in the 5-8 ms region.
Those are starting points for the system and tweaks will probably help.
