Unbalanced Hookup?
Allen
I have an amplifier with only unbalanced inputs. What is the correct way to hook it up to my dr260.
Do I tie pin 1 & 3, or just leave pin 3 open?
Allen
Allen
Steve
I found a simple diagram in a crown owners manual if you like pictures. See figure 2.4 for unbalanced xlr connection in the manual.
http://www.crownaudio.com/pdf/amps/139441.pdf
The wiring diagram (figure 2.4) in the Crown manual linked above should never be used. It is one of the worst ways to do this. The proper way is to use the wiring method of figure 2.1 from here:
http://www.jensentransformers.com/an/an003.pdf
This will usually result in a 10-30dB lower noise floor depending on the design of the unbalanced equipment and the magnitude of current flowing in the ground loop.
Arne K
Arne K
On the input side of the DR, things are somewhat different. Most consumer gear with RCA outputs have a maximum output voltage of about 2V RMS (8dBu). This is still plenty of headroom in the DR even if it is set for +14dBu input operation. There are some pieces of consumer gear that can output up to about 7V RMS (+20dBU), but they are fairly rare. If you are just talking about a typical receiver, it won't put out more than 2V RMS.
I would set both the input and output jumpers in the DR for +14dBu operation.
Thanks Jack! pleased to have your contributions!
Good point.
I also have an Shure P4800 that has a software controllable 20dB pad for the outputs. This makes it very easy to use for multiple applications. I wish it was selectable for 0, +10 and +20dBu though.
Then I can keep it at the 14dB setting ;-)
Arne K
