Driverack spikes/Pop on power down?
Just got my new Driverack PA and am indeed pleased. Big improvement in sound!
I've read a lot about the spikes/Pops on power down. How can I best protect myself from this? I understand the order each component should be turned on/off. I know a UPS will help, but I'd like to hook everything up through a power conditioner and be able to shut it all off with one switch. I am most concerned about how helpful my friends can be in powering things up and down. Any good ideas?
Gadget recommends soldering (hard wire) the cable inside the DRPA chassis to avoid pull outs and while you're in there, jump (by-pass) the switch.
I will get a power conditioner and UPS. Now if I could only keep my \"helpers\" at bay. I had a thought. If I placed the UPS between the power conditioner and the Driverack, wouldn't that give me a bit of additional protection for power loss issues (or would it negate the benefits of the conditioner)? If I lost power, the amps would immediately shut off, but the Driverack would still stay on for a few minutes. Seems like a good compromise.
Nice little unit, though. I find myself playing with it each day to see what else it can do. I am definitely finding that less is much more.
Gadget?
I wouldn't chance it... I even put the DR260 on a UPS... In the event of power failure this allows for the amps to fully power down before the DriveRack... This would be the normal power down sequence and is how it should be done anyways...
Kev
- scott
